has anyone noticed a big difference in a second battery?
if your alt cant charge up your batteries A the alt is junk B you listen to sine waves C you dont have the battery installed right D you shouldnt try running 3500+ watts on a factory 100 amp alt and have the volume at near full volume 95% of the time
If you want to see the benefits of a second battery, you have to keep in mind that the charge/discharge rate of the battery is going to determine whether or not you will see a benefit from the second battery. Think of a battery as a bucket of water, a normal battery will only allow you to **** out a drinking straws worth of power out of it at a time. If you get specialized car audio battery, you can increase that drinking straw to a gas powered water pump. I highly reccomend a kinetik battery. Optimas not soo good. If you are going to add a second battery get a good quality battery, and USE AN ISOLATOR. If you do not use an isolator, you will cause your factory alternator to fail prematurely. I ran a 2000watt system with a facttory alternator and dual battery setup for 3 years with no power issues at all.
I didn't use an Isolator in my Lumina and I ran 2 batteries for almost a year with no problems at all.
I'll be doing the same in my Impala. And if the alt fails.... it will give me a reason to buy a HO alt :p
The isolator costs you .7 V. If the point is to keep the voltage up, an isolator doesn't make sense and it usually isn't needed anyway. The charge/discharge rate is determined by the battery's ESR. Optimas are actually pretty good in that regard. Kinetics and the other car audio marketed batteries are as well of course.
mustanggt5330
mustanggt5330
chicago,IL
helotaxi
vegang
vegang
