Has anyone built the TriTrix from PE?
Well I guess I'm just gonna go for it. I've read some pretty good reviews on it at other places. Plus the speakers are so cheap, its not that great of an investment. One thing I'm wondering is if I can swap the shielded 1-1/8" tweets for the unshielded ones. They should be the same right?
i always wanted to do one of thier projects. like the hivi juniors - http://www.partsexpress.com/projectshowcase/hivijuniors/index.cfm .i just have no idea how to put together a crossover. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif are there any tutorials anywhere that go in detail about putting one together? or forum members that design em?
It gives you a design, just find a couple of project boards (the ones with holes) and join the wires on the back side making sure you don't get any wires touching that shouldn't be...
Or if you like the full range craze http://zaphaudio.com/audio-speaker18.html
Make sure to use the filter
That driver and design replaced the Tang band (your driver) as his favorite for a reason...
i was trying to find that page all morning, thanks.
reading through that article , guy talks about unwinding inductor coils, quick realease crossover components. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
it looks like it would be a great build but i feel i dont have enough expierence yet. are there any other full range projects floating around the net?
It's a basic crossover;
http://www.partsexpress.com/projectshowcase/hivijuniors/schematic.jpg
Resistors = Rp1, Rp2, Req
Capacitors = C1, C2, Ce
Inductors [coils] = L1, L2
You buy the parts and wire them up as shown in the drawing.
You can attach the parts on a piece of wood, plastic, whatever and wire it.
Some ideas;
Random pics;
Simple - piece of wood, glue the parts and solder the wires.
http://www.facstaff.bucknell.edu/esantane/movies/CompletedCrossover.jpg
http://www.facstaff.bucknell.edu/esantane/movies/hatt.html
You can install the crossover inside the speaker box, but ideally you want
to be able to remove the crossover just in case you need to do some
tweaking. Perhaps make an access panel in the back of the speaker box,
or the crossover can be an external unit as well. Whatever you can dream up.
http://www.facstaff.bucknell.edu/esantane/movies/MountedXO.jpg
A similar idea with a terminal strip so you can wire up the connections easier.
http://www.troelsgravesen.dk/SP_38_files/SP38_28_domescrossover_1.jpg
Scroll down to see how this is integrated into the cabinet.
http://www.troelsgravesen.dk/SP_38.htm
A ghetto method where you attach the crossover parts to the speaker
wire, it works fine, it just looks funny.
http://www.dansdata.com/images/speakerkit/xovers560.jpg
more pics
http://www.wmeckle.com/ARIA5/Aria5Xover.jpg
http://www.guerrillaaudio.com/store/bunker/images/110-1091_IMG.JPG
A custom design would probably look like this, where you did PCB layout,
etched the copper clad board, etc. More professional looking, but it will
function the same as the others.
http://www.dansdata.com/images/f5/bits1024.jpg
You can also try pegboard as the base, install the parts and use
wire ties to hold the parts in place.
http://upload.wikimedia.org/wikipedia/commons/thumb/6/6d/Pegboard.jpg/800px-Pegboard.jpg
http://www.hometheaterhifi.com/volume_8_3/images/audax-center-channel-midrange-crossover.jpg
http://www.partsexpress.com/projectshowcase/images/surrcross.jpg
very , very nice post. just what i was looking for.
that just gave me the boost i needed. i think ill go ahead and try this out very soon.
couple more q's though...
on the high pass L1 and rp2 are to both the + and - ?
same as the LP side with the c2 , ce and req?
whats a L-pad? eq?
and when i go to order the components , do i just look for the values? rp1 - 2 ohms , rp2- 6ohms etc..
im just trying to understand this before i go ahead and dive right in.
thanks ALOT for the help guys. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
this will be my first REAL diy also. the other one i did was baiscly get a full range driver , throw it in a box , and call it a day. i think it sounds great, but i know it can sound better.
btnhfan
Hail to the King Baby!!!!
btnhfan
CT/ GA Tech, Atlanta
BrianChia
