Hard deciding between 10's or 12's
do you even have enough height to run a 15" driver face forward or face backward?
you may only have enough for driver up with a 15" , can not remember how much usable height you have in the fusion ?
i wish i had a turbo , so....... LOL
I have a 10” Alpine SWS and a 12” Alpine SWS. The 12 is louder but I prefer the more accurate bass of my 10” for whatever that is worth to you. Both are on the same make on the same power and both ported. The 12 is now sealed because I like it better that way but the 10 ported is just right. I have a hatch and a van though so not sure what that trunk will do to the bass.
Ill make my own box, ported and I think a T-line will test my abilities. I can make square things pretty good.
this area is 40 inches wide, 18 inches tall and I can go 20 deep and still have some good room.
I built a t-line last summer for a single 8. It's around 3 cu ft once all said and done. Bigger than typical single ported 8's. Now I can't imagine what a t-line would be for 2 10's other than bigger than your trunk. Your better off with a reg standard ported/vented enclosure, keep thins simple, and still utilize your trunk some.
This is the t-line I built. As you can see, it's just in front of my 15's enclosure....in the back of my Tahoe. Also shows the size comparison for everything around it's environment.
What are you running in this pic for subs and amp? May be getting a Suburban soon and will probably run 15's.
Sent from my SM-G950U using Tapatalk
my accurate size I can build is 40 in wide, 17 high, bottom width at 22 and top width at 18. OD dimensions which will allow some space around the edges
you should buy my pair of soundsplinter rl-p15s then //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Polar
Polar
WPB, Florida
BOOMINGRANDPA
