haha... even more sub questions......
jflick092
Work Do'er
ok so..... i have the peices for my box thats 4 cubic feet. right now i can still change up the port to tune it, as its not built yet. i need help choosing a sub for the price...... well. i wanted a FI BL 15, but they are out of stock plus cost more then i would like to spend, then i wanted a audioque HDC3 15" but they cost alot for aluminum, and the mounting depth is very close, i would have to double baffle it with 3/4" mdf, and i would still have less then half an inch for the pole vent... Ive also wanted an RE SX 15" which i would have 3/4" for the pole vent with out double baffle id probably put 1/2" MDF for the double baffle... (height is limited) uhhh. so im probably gonna go with the SX.... how would you compare it to the other 2 subs listed?
and i would most likley buy the sub off of ebay for around $237
and hifonics bxi1608d off ebay also. running 1 ohm at 1600watts
my box demensions are 25.5" x 38" x 9.25"
can anyone tell me what the length of the port wall should be? the L shape...
here is the specs that im trying to use, sorry about blurry image.... enlarge it
and that print is tuned to 27.9, where the sx is rated 27.8..... close enough right?
http://s200.photobucket.com/albums/aa224/sk8ergangsta2003/?action=view&current=SUBBOXFORRESX15TUNEDlarge.jpg
OR go with a tripple baffle around the sub if you have the wood to get mroe clearance - you want at least as much clearance as the pole vent is across.
4 cubic feet - look into AQ 2.5SD woofers 15"
Or a SSD from Fi
dont know the pole vent size, dont think the site says... and id like the RE sx.... as i like it alot and it does have a mounting depth that i could fit. i dont think i have room for a tripple baffle, because my box dimensions are made to just fit in my trunk. the full width, the height can only fit around 9-10" because its like a trapezoid near the top so i cant fit the box up there if that makes any sence? for the SX with the 1/2" baffle itd be around 1 and 1/4" clearance for the pole vent. not sure what a regular pole vent size is...
any help on the box vent dimensions??? i dont know how long to make the vent"wall" part. or what to tune to.
wow i feel dumb... the recomended tuning for the 15 SX in 4.0 cubic feet is 34 hz so yeah... guess that box plan i made wont work....
photo bucket? the things from REaudio.com though. k thanks ill see if i can....
crap.... my car battery died today and we jumped it... but idk. is this bad for when i get my sub? will it die really fast????
jflick092
Work Do'er
jflick092
Ohio
jflick092
BP1Fanatic
BP1Fanatic
