IIRC most alternators as well as HO alternators can take 20k+ rpms. and most are also 2.5-3:1 ratio (if i remember correctly). that means he would have to be revving his motor up to 7k rpm for extended periods of time....and i dont know anyone that does that, now if you drive an import with a high redline and you race it, then maybe...hell my redline is 5k rpm. get a smaller pulley, youll be fine.If you go with a smaller pulley you run into the chance that at high rpms it spins too fast which would be a bad thing.
My HO does the same thing and its annoying, but its not like my car is going to stall at idle or anything.
No HO alternator produces much power at idle. When you look at all the alts out there you will see a common issue and thats power produced at idle.
also make sure the belt is perfect,
any looseness = slipping @ idle = glazing the pulley = more slipping = worse and worse progressing voltage and alt belt squealing eventually if u let it get there.
Agreed, try upping the idle rpm by a few hundred, not too much - give ur brakes and gas mileage a rest, i mean dont crank the idle or anything...
You wouldnt by any chance know how to do this would ya?
Also, getting a nice batt (kinetik or yellowtop) helps ALOT. so do it.
I had the same exact problem when I bought an Excessive Amperage alt from Nathan, spent 300 for it. I emailed him about it and he says that the alt could be bad and says to go ahead and send it to him when I getta chance. Well needless to say, on my way home from work one day my blzr just died. Wouldn't start and couldnt jumpstart it. I sent Nathan the alt. he tested it said that he couldn't find anything wrong at all. Of course I was surprised. So I explained the situation that I was loosing vlotage at a stop sign or stop light....whenever I was stopped. So he suggested that he redo the guts inside of the alt for 150 bux and says the RPM's could be the problem. Paid him the $$, got the alt back shortly, installed it and havent' had a problem since. BUT....I did notice my battery light would come on all the time when this situation happened. I even had a nice Costco battery but I think Nathan fixed it. And I've had it back since Jan of this past yr.Well... after 180 bucks, I bought a brandy new alterstart 180a alternator for my tahoe. Well, after i installed it, I have worse voltage than i did with my stock 100a alt. I dont get it. I got the big 3 done, on a stock battery.
Its like... when i pull up to a stop light, with foot on the brake, the voltage just drops.... no music or anything. As soon as i drive it shoots right back up though. Someone have an idea?
Thanks!
im assuming your just trying to make it easier for most people to understand in the first bolded quote. but alternators dont use magnets. electricity running through a conductor will create a magnetic field. the magnetic field has a north and south pole like that picture, and it induces voltage in the stator.This is a very very common problem and very easy to fix. The bigger problem is the lack of knowledge on this issue...
An alternator is nothing but an electrical generator. It spins wires near magnets which move the electrons in the wire, thus creating electricity.
Amperage is simply the number of electrons that are moving. Obviously, faster spinning causes more movement, or higher amperage.
In the case of your alternator, the rotation of the wires varies directly with the rotation of your engine. Meaning, for those who haven't passed 7th grade math, that the faster or slower your engine is rotating, the faster or slower your alternator is rotating.
Now as we all know the rotation of the engine is far from constant, therefore the rotation of the alternator is not constant, and again the amperage produced by the alternator is not constant. At low RPMs your alternator will produce lower amperage than at higher speeds.
This is where people run into problems. Their alternator doesn't produce enough current at low speeds, but they are fine at higher speeds near their alternators peak output.
The alternator is not directly linked to the engine. There is a pulley which connects the engine to your alternator. Think of it like the gears of a bike. When you shift into a higher gear, the chain jumps to a smaller sprocket, and every time you pedal the wheel turns more than it did in a lower gear. The alternator works the same way. If you put a smaller pulley on it, the alternator will turn faster with the same amount of engine RPMs, which will solve 90% of people's high output alternator problems.
