2008 altima coupe install questions
hemi=22s
I Pop Bottles
need dash kit, bose amp bypass harness, antenna adapter
anyone have a wiring diagram, for after amp colors of speaker leads
also need help on installing pac steering wheel control interface in conjunction with a deh=p980bt
car says 9 speakers, 2 10" subs, 2 rear 6x9s what r the other speaker sizes
heres what else goes in, optima yellow top x2
0 gauge amp kit
premier component set front door
premier d series 6x9s
eclipse 75x4 mids amp
mmats d2100.05
2x 1 farad punch capacitors
custom fiberglass box
blue granite amp rack to match car
subs dont have yet either mmats, re or dd 2x 10 subs have everything else
That's kind unnecessary... He spits the troof... Best place to find the bypass harness, I'd imagine, would be a retail outlet... Like Best Buy or something to that affect. And don't ask a sales guy, walk straight back to the install bay and ask. They can sell it to you there, where as the sales people know very little about the harnesses as they don't have to deal with them much.
that wasnt in reguards to the items, i know this, they dont have em at best buy or circuit city, because metra doesnt make the bypass harness yet
i was looking for a different company besides metra that makes amp bypass harness, and help with install of the pac steering wheel control, size of factory spreaker in the car with the bose 9 speaker package so i can order replacement s before i get the car
i thought thats what these forums were for help, info if he did not want to offer assistance he should of not posted anything at all
The car is too new. No one makes a harness yet. Same with the dash kit. I'm looking at a new Infiniti and having the same issue. The stereo is an integral part of the car's computer. It isn't going to be a simple matter of pulling out the CD player in the dash and adding an aftermarket unit. The steering wheel controls are wired into the data bus for the car as well. Not going to be a simple solution for those either. Good luck.
actually it is quite easy dash kit is made by 2 different companies and out everywhere now metra 99-7423 and american inernational? dont know part#
also got the stero harness and anntennas adapter just no amp bypass harness yet metra is working on it tba release date, i am going to just unplug speaker outputs harness from bose amp and splice some t-connects on there and this will work perfect until it comes out
does anyone know where to get the wiring diagram for this car with bose 9 speaker system?
actually it is quite easy dash kit is made by 2 different companies and out everywhere now metra 99-7423 and american inernational? dont know part#also got the stero harness and anntennas adapter just no amp bypass harness yet metra is working on it tba release date, i am going to just unplug speaker outputs harness from bose amp and splice some t-connects on there and this will work perfect until it comes out
That's actually quite surprising. They still haven't figured out how to integrate everything with the '07 Infiniti G35 sedans (same basic layout as the Nissans) or the '07 Mazdas. What do you lose off the basic setup with the new harness? I guess all you really need to install a basic radio is the power connections anyway. Run new signal cable and you're all good with aftermarket amps and speakers. If you want to know what size they are, pull them out and look. The Infinitis use the 8" front door speakers in the Bose system.
hemi=22s
I Pop Bottles
hemi=22s
west palm beach, fl
helotaxi
vegang
vegang
