H.I.D help
robert420
ive been looking all over the internet to find a conversion of some sort so that i can run HIDs on my 87 chrysler. do they make kits for the glass halogen bulbs? or do i have to cut the glass, remove the prongs and adhere it in myself?
With hids, you change the bulb,don't modify the housing.
You will have to enlarge the hole where the wires come thru the cover.
Wire's from ballast to hid bulb,wires from factory to ballast.
should also say im not recommending that brand because i know nothing about the xenons they have. but you need the housings so you have housings that hold a regular bulb look around on ebay find some housings you like and order those then order your xenon kit or order a combo kit like that one
With hids, you change the bulb,don't modify the housing.You will have to enlarge the hole where the wires come thru the cover.
i'm aware of this... my lights are sealed halogens...
robert420
robert420
geneva ne
trumpet
