Ok, this is what happened. This weekend my Stinger SPV35 died, it is used as my starting battery. I decided to try and charge it back up, see if I could buy a few more weeks before I buy a new one. Its about 4 years old so its probably about time. I charge it up, and its starting the car beautifully. I then close my hood and thats when my day got bad. Keep in mind this is the first time I've ever taken this battery out of this car, it was installed when I bought it 3 years ago. It's not a direct replacement and there had to be some modifications to make it fit.
After a few hours I go back out to the car and see if its holding the charge. Turn the key, nothing happens. I pop the hood and I see a burn mark on my hood, I must not of put it back in the right spot and the terminals were touching my hood! So obviously I'm guessing I grounded out my battery, although no fuses blew whatsoever. I bought a new Yellow top and now all is good. I drove it around a few hours yesterday and today with no issues.
To add, today I hear a scraping noise under my car. The cover to my catalytic converter had rusted and is dragging the ground. I then notice that the O2 sensor cable has been frayed. I turn on the car and the Check Engine light is on, and the Battery Light...... My owner's manual says if the battery light is on, the battery isnt charging.
Is it possible I did damage to my alternator when I grounded out the battery, or did possibly grounding out the O2 sensor trip the battery light and maybe it will turn off eventually?
I don't have a DMM and my cousin who's a mechanic will be checking out tomorrow. I just figured I'd get some opinions.
CLIFFS: Grounded out battery, bought new one. A day later my converter shield falls off and frays O2 sensor wire. Battery light and check engine light come on. Is alternator damage, or did batt light get tripped when O2 sensor possibly blew?
