Ground Zero Audio?
ground zero is not a TC rip off, TC used to make their woofers, then sourced their drivers elsewhere (directly). Ground Zero makes great equipment, subs can get loud, their high end amps are top notch.
GZ usually does well every year in DB Drag Euro
a lot, not many stateside, the woofers are tc sounds ripoffs. I was quoted 800 euro for the high end driver.
That's a good quote, where I live (sweden) you have to pay close to 1300 for the Ground Zero GZPW15SPL and close to 1500 for the 18". I do not know if that line is their top line though.
GZ is pretty well known around here, but not well used.
GZ USA went under a few years ago iirc.
The GZ Nuclear (Nuke) use to be the envy of everyone on the audio boards. It was the first of the extreme excursion 'super subs'.
Like said above, they still have a solid reputation and market in Europe. As far as I knew, GZ USA and the original GZ based in Europe were seperate entities.
yeah.. tc designed and built there woofers, gz then took them, and had them copied elsewhere. that sounds like a knock off to me.
Digital Designs
Aclministrator
Digital Designs
Limestone NY
visitor
