Ground wire.
The black ground wire is in the harness. The harness connects to the headunit directly. It cannot be grounded to the chassis or battery. It is just designed to connect directly to the headunit. Should I connect it directly to the headunit?
what the hell are you talking about? there should be a black wire in the radio harness. ground it. is this an aftermarket headunit?
Yeah it's a aftermarket headunit. The harness connects to the headunit with the ground wire in it, so that means the ground wire connects directly INTO the headunit.
Assass1n
Assass1n
New Zealand
Assass1n
