Ground Help
xxBURT0Nxx
Team Ramrod
Okay, so I'm doing the big 3 on my car right now. When grounding I am sanding the are before I put the bolt in. Problem is, when I putt the dmm on the pos of the bat and the neg I get 12.6v. When i put it on the pos of the battery and touch the other prong to the sanded area i get 0.4v. Is that okay? Or should it read 12.5ish v when it's just touching the sanded down area? Do i need to find a better spot to ground or what? Thanks!
Is your battery grounded to the chassis from another wire when you do this? If not, you're reading is correct.
The DMM can't ground your battery to your chassis. It only reads voltage.
Alright, well i sanded further and now I'm only getting 0.1v so I think I need a new ground location. Here is a picture of the current ground:
Also, will the screw hole on the left work to ground the engine block in this picture:
I use a 60 grit on a dremel. Gets the job done in a few seconds //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You can't test the location for matching voltage of the battery unless you also connect the ground wire. With the ground wire attached to the chassis and the battery, place the DMM on the battery positive and ground chassis. You should get the same voltage reading as when you touch the battery negative.
.1 volts when testing the way you are testing is a good sign that the location will be a good ground.
As for the block to chassis ground, I just used the existing ground location and replaced it with my 0 guage.
Was that screw hole in your picture already open or did you remove the screw? Do not place a new screw into an old location that had no screw. I do believe that some are intentially left open by the engineers.
Yeah, but I'm pretty sure my current ground is what is causing the problem. If i probe the pos terminal on the battery and then the wire that grounds the battery (when the wire is disconnected) I only get 0.6v... that's why I'm trying to find a new ground
the body of the car should act like a neg post in this case me thinks
ONLY if he has the battery grounded to the chassis by another wire. Otherwise he's touching a positive on the battery and never touching a part that returns the current to the battery to create the ground. As I said, the DMM cannot be his ground.
but a LOT of the cars electronics use the body as a ground.
In that test (with the ground disconnected from the battery) that is a bad grounding spot. But not because it's too low at .6. It's too high! It should read .2 or less I'd say.
okay i think that makes sense.. the battery isn't connected right now and I'm getting 2 volts when I touch the wire that I just connected to that ground I made. Guess that's a good sign that when I connect it to the battery I will get 12v again?
Also, that hole had no screw in it... what if i use the one to the right of it where there is a screw?
sand it and go with it
It doesn't matter if the battery ground is not connected in ANY WAY to the chassis. None of his electronics are connected to the battery ground to cause the ground you speak of.
xxBURT0Nxx
Team Ramrod
xxBURT0Nxx
Denver, Colorado
xxBURT0Nxx
NorthFramingham
    Jun 30, 2026
