Ground confusion - someone help me out
Ok so I've always heard mixed things when it comes to the ground wire of an aftermarket harness.
If you're using an aftermarket harness that plugs into the factory radio harness can you simply splice the black ground wire to the aftermarket radio black harness or do both need to be connected to metal near by? Does it matter? Thanks
use the factory ground, dont worry about grounding it elsewhere unless you run into problems.
myfavecoupe
myfavecoupe
Massachusetts
myfavecoupe
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
