Great amps for the 150 to 200 wrms range
So far the massive bx2 looks the part. Has anyone used it before? Any other small amps have an OEM auto sensing music remote turn-on?
I'd get the apsm 1150, 300 rms and a small footprint. Only con with it is the gain control is under the amp so when you mount it make sure you have your gain set where you want to keep it.
Yeah, these are listed as 3ohms nominal and that is why you see the 2.7ohm rating (where they can drop to). There are a number of things wrong...
929
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
201
442
damiandevika
damiandevika
Trini
Dirtrider4eva
    May 20, 2024
    May 20, 2024
