frankiebones
I tried to make a graph but couldnt upload it, regardless the chart is uploaded. i wasnt expecting anywhere close to 5 but i certainly wasnt expecting under 1 V for almost the entire vol band.
I did not have the time to get each readings with processors and EQs in the mix but I did a few that were a lot higher using the 50Hz test tone (0 dB). I will do the rest later today.
I had the leads of my DMM directly touching the RCA connector. I made it easier on myself by wrapping Velcro ‘tape’ around my arm rest in my car to keep the RCA cable stable so I could, uh, y’know, probe it for lack of a better word. I ended up being able to tuck both the (+) and the (-) leads of my DMM under the Velcro so that they were making very solid connections to the RCAs without me doing much to hold them there.
Sure enough, after I had turned the volume all the way up and logged each value, I slowly turned it down and on the DMM confirmed each voltage to the third decimal in many cases. then when I was forced to switch from a 2V range to a 20V range, I checked for a 3rd time to make sure that the values would be the same. My DMM at both ranges used is accurate +/- .5%, so unfortunately for me (I’ve been listening to my system with only .262 V preampwhen messing wityh my EQs) and maybe also for you if u are reading this, these pioneers don’t go close to the ~2.5 volts you would assume they actually get if they advertise they get 5V. also, here is a graph, I will also be doing a logarithmic analysis to determine clipping later on in the day (thanks thcn).
P.S. The sound processing I was using to get the values in the right column are as follows:
BBE - +2
BMX +1
Also, I was boosting both my 31.5 and 50 Hz EQ bands +2 dB, which from what I know is gonna ask the amp (and I guess the HU also) for a lot more power
BBE - +2
BMX +1
