Darkhojo
I've decided to go with a sealed box for my sub, my friend is helping me build it soon. However, I'd like to know some things before we start.
Where can I find a box program?
and
How do I tune my box to this sub's specs?
Here they are:
Diaphragm Material : Carbon Fiber/Aluminum Honeycomb/Kevlar Reinforced Pulp
Magnetic Weight : 130oz.
Mounting Depth (top mount) : 218 mm (8.6")
Mounting Diameter (top mount) : 231 mm (9.1")
Recommended Box Types : Sealed/Vented/Bandpass
Recommended Sealed Box Volume : 0.75 – 2.0 cu. ft.
Spider Material : Nomex®
Voice Coil Diameter : 75 mm (3")
Power Handling Capacity (Peak) : 3000W
Power Handling Capacity (RMS) : 1000W
Coil Height (Hvc) : 48.1mm
Cone Area (Sd) : 529sq. cm
D.C.Coil Resistance (Re) : 3.6ohm + 3.6ohm
Electrical Q (Qes) : 0.69
Equivalent Suspension Stiffness (Vas) : 32liters(1.1cu.ft.)
Free Air Resonance (Fs) : 28Hz
Frequency Response : 23Hz - 200Hz
Gap Height (Hag) : 10mm
Impedance (Nominal) : 4ohm + 4ohm
Linear Excursion (X linear) : 19.1mm
Maximum Excursion (X peak) : 22mm
Mechanical Excursion (Peak-to-Peak) : 75mm
Mechanical Q (Qms) : 8.67
Sensitivity : 83dB/W/M
Total Loudspeaker Q (Qts) : 0.64
and
Here they are:
