got jacked!! new 8s or 12s HELP!
ok now im going to run nothing but sundown nothing else so dont say i dont want to get my head all mixed up with countless subs.... i was looking in my truck and here is what i can do.... 2 8s in a ported box behind the seat and 1 8 in a custom center console (ported of course) or 2 12 ported behind my seat... so now the decision begins!!
after a few days of thinking and what not i decided to get 2 SA-12, i am also going to do a cut through with the little space i have (due to air ride suspension) so now my main concern is the inside of the box..... never built a ported box only sealed so ima need some help!
here is what i came up with.... 15in H, 13in D, 53in W..... 1/2 Gross 5.06 C.F, 3/4 Gross 4.63 C.F...... it says i need 1.75 C.F for each sub.... will what i came up with work? like i said i never built a ported box before... Thanks!
That should work, may be just a little on the small side. You gotta consider bracing displacement, port displacement, as well as sub displacement, but I think you could squeeze it.
yeah so im sort of aiming on using 1/2 wood so i can have a little extra for the port, sub, and bracing
I for sure wouldnt do that. Just let it be a little on the small side. Power, polyfill, and tuning will deal help tweak the box, but building it out of 1/2" just isn't too smart. stick with 3/4" for sure!
ok thanks now ill start with 3/4! now this whole tuning thing it says i need 30hz i came out with 32hz but the port is 1.5in wide.... does that soind right?
another question i had about the whole 1/2 3/4 wood.... since it is a cut through i was going to spray some rhino liner or something so the box wont get wet..... if i were to go with 1/2 would the rhino liner make it more stronger?
Good stuff...
And if I am not mistaken, you want 12 square inches of port for every cubic feet the box is. So, that would be on the very small side. Since your box is 15" tall, the port height will actually be 13.5", times that by 4" and you should be good... And tuning is very subjective. If you really want it to be more loud, tune to around 35 or 36. I personally like to tune lower, more around 30, but I am not looking to be super loud, I like the deep, low bass. A good thing is, though, is the higher your tune, the less box the port uses.
Good stuff...And if I am not mistaken, you want 12 square inches of port for every cubic feet the box is. So, that would be on the very small side. Since your box is 15" tall, the port height will actually be 13.5", times that by 4" and you should be good... And tuning is very subjective. If you really want it to be more loud, tune to around 35 or 36. I personally like to tune lower, more around 30, but I am not looking to be super loud, I like the deep, low bass. A good thing is, though, is the higher your tune, the less box the port uses.
Ok thanks! now i have a pretty good idea on what to do, i do want to be loud so i will take your advice and tune it around 35-36.....Thanks!!
Bggd_GMC
Low & Loud
Bggd_GMC
Fresno, CA
Bggd_GMC
