got a problem...pls help
no fuse there sorry i misunderstood. theres a 15a fuse on the back of the hu that isn't blown. no ****ing power to it anymore though. i cannot figure it out
You probably have a short in the wire somewhere. When you touched the ground it may have melted the jacket somewhere and now there is an intermittent connection causing it to go in and out.
haha i probably ****ed two things up yesterday...hu's bein looked at tomorrow to see if it's fried...and i found out last night when it became dark out, my interior lights will not come on when the car's off or on, everytime i turn the car off my factory hu forgets my presets, the time, and the eq settings. my remote on my keys will not unlock or lock the doors, can't roll the windows down unless the engine is running, same with the locks............anybody has any input fill me in lol
check all your fuses in your fuse box
Definitely this.
Also, again, check all your wiring. If there is a wire touching (causing it to ground out) then your constant wire might be jacked. Causing your presets not to work. But definitely check your fuses, I almost guarantee that there is 1 or 2 blown in there.
CMattox23
CMattox23
Delmar,MD
CMattox23
