got a few questions
jdawg90
I've got a run of 1/0 going from my trunk and ran out of wire just before the firewall. Is there a good way to connect another strand of 1/0 that will go through the firewall and to the battery? Only thing I can think of is just adding a second inline fuse holder or dist block.
Also does anyone have any suggestions on what screws to use to mount my subs to the box (SA-8's)?
And is the area under the trunk floor that holds the spare tire an acceptable place for the amp ground (I drive an accord)?
thanks
you can buy 0g couplers and as far as screws hex head screws are real nice as it's a lot harder to slip with an allen key, for a ground use a dmm to find an area in the trunk with the least resistance.
jdawg90
jdawg90
alberta
goingdef
