1. Does 6 drivers @ 8ohm make a final load of 4ohm?
2. What if 7 drivers @ 8ohm, what's the final load?
3. Can I connect 6drivers or 7drivers on one http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-144 , i want 5 or 6drivers respectively play 3000hz and below, the last driver play all the above
4. How do I high pass the woofers crossed 3000hz and below?
5. What good brand of home audio amplifier/receiver are the best bang for the buck that does around 150rms @4ohm, of course more is better but i find that they are all expensive, and don't know what is good in home audio, I need something that will control gain/volume/hpf and eq if possible and aux input for connecting to computer for around 250$ ...
