Good Multimeter and Soldering Iron...
x2 on the Weller gear...I've got two, a little 25W "pencil" iron for PCB work, and a 100W for antenna/coaxial connectors (PL-259's need a ton of heat, especially when a dipole goes out in the middle of winter) and wire splicing.
My Greenlee DMM has done fine, Fluke gear is primo but carries the primo price tag //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The variable heat stations are kind of nice, mostly because you can turn it down if you're doing small stuff (a resistor) and dial it up big time if you need to (soldering a 0 gauge wire). The Weller I use is really nice, and you can't go wrong with a Fluke meter. However, if you're only doing light work on a rare occaision (to make sure you're getting 12v at your battery, for example), then just about any meter will do. They've got a decent one at Radio Shack for like $20.
I use a Fluke. Haven't found anything more reliable. 179V Something or other. True RMS. Cant go wrong.
I use weller electric soldering Iron 140/100 watt. Cant go wrong there either.
I also have a Butane Snap-On Soldering Iron I use quite frequently. Very convienent, but you can burn the shit outta yourself if you aren't careful. LOL.
Buckshot
Buckshot
Michigan
Nikuk
