Good glue to seal speaker
I have 2 w6 12s that I had the outside foam replaced by a professional repair company but that did a sorry job on glueing the foam back to the center which only lasted a month so what's a good glue to use
E6000 adhesive (target, walmat, home depot) and some clamps from home depot. It works better than CA glue or amazing goop. I've had zero problems with it and I'm playing 22hz really hard on big power big boxes on my 18s. They show no signs of weakening at all. Takes overnight to fully cure.
What's kind of clamps are they.
the cheapest ones you can get. Spring clamps.
I got one of these when it was only 5.99 you can use every last piece no problems. you can also buy it piece by piece depending on how much you need and if you want to do one sub at a time. or just spot repair, you will need a lot less. There's a whole section for it so just check it out. Its just there to help the glue properly set and cure. You can use anything for weight on the surround after applying the adhesive as well.
Spring Clamp Set (22-Piece)-TGS0073F - The Home Depot
415slams
415slams
sanford,fl
415slams
RobGMN
    Jun 8, 2026
DEH-P7700MP.mp4
lbn.wrks
    Jun 8, 2026
