Good day gone bad
yeah i dont know how i blew it on 300 watts rms...and yeah i am the original owner of them but i am going to be building a new box this weekend just for the 1 type r that didnt blow...i am thinking 2.5 cubes at 32 hz should sound good on 600 watts rms but yeah shine cause i grind is pretty rediculous
well i hit 139 .7 db with them at 300 rms....how should i wire this up to a two channel amp....its a dual voice coil 4 ohm sub....it should be negative to negative then positive to positive then positive to positive on the amp then negative to negative on the amp right for a 2 ohm load
that turns my bad days good.
You definitely must follow function over form because that is one of the ugliest installs ever, but I bet it sounds amazing. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
x2 im sure it sounds amazing but it looks pretty bad.. id try to do something with the mdf.. paint it or something
something doesnt sound right, 300w blew it? hmm
ive seen inexperienced idiots running 1000w to each way playing below 30hz tones quite often and didnt blow it for a LONG time
Same thing happended to me after one of my rf T1000.1bd got injured.I ended up running my 2 RF T2's(1000WRMS) of one T1000.1bd(aprox1400 WRMS) and messed up one of my subs. WTF
why would you think it sounds amazing? by its looks? So it looks like it sounds amazing?? then it must look amazing...
No, by the equipment you are using it should sound amazing. Also, you did a good job of aiming the tweeters and mids which should allow for good alignment and time coherence. It is definitely a quality install, it just isn't pretty, lol.
AlpineUser
Bumpin
AlpineUser
St. Charles Mo
bose301s
