good amplifier?
hottchineseboy
i got a UL400HC ultra linear amplifier... it says it can push 1200 RMS but uses 3 30 amp fuses can someone break it down for me in the RMS power with fuses? and tell me how to do it?! and are these amps any good? from what i heard there pretty solid but i just your guys inputs
thanx
i got a UL400HC ultra linear amplifier... it says it can push 1200 RMS but uses 3 30 amp fuses can someone break it down for me in the RMS power with fuses? and tell me how to do it?! and are these amps any good? from what i heard there pretty solid but i just your guys inputsthanx
I think you just multiply the amperage by the voltage so [3 30 amp fuses] x ~12 volts = 1080 watts
90 amps x 14.4 volts = 1296 so your amp falls somewhere in between being the amp is efficient enough to produce those numbers.
^what he said.
But when you factor in the eff. of the amp and the fact that a 90A fuse isn't going to blow the instant it tries to pass 91A - or 120A for that matter the calculation becomes pretty irrelevant.
The fuse estimation is ballpark at best. It's really only useful at the pawn shop when you see a 1000 watt amp with a 15A fuse.
Truthfully, I've never heard ofUL400HC ultra linear amplifier!
^nice *** //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
OFF TOPIC: Thanks, it's Brooke Burke's. I might change it later to a huge ***/thong shot of Vida Guerra. I don't know though. What do you think?
hottchineseboy
hottchineseboy
kent, wa
playa1
