Good alternative to Sundown??? 2000w rms
Anyone know where I can see a test done on them? I remember seeing a test donw between a Sundown 3500 and an AQ3500 and the Sundown raped the AQ. Jacob from Sundown did the testing. He did comment that it was a great amp for the money.
Lookin for something OTHER than Sundown. Its a bit too pricey for me at the moment.
I was lookin at the AQ amps, but I heard they are rated at 14v and dont quite do the rated power.
They won't do 2200@ 12 volts like you were asking, but they do rated. Many people have done the testing.
Not sure what other companies rate at 12 volts. but if that's what floats your boat, you should stay with the Sundown. You could get an AQ3500 and the 4x90. If any are left the 3500s were 549 shipped.
Heres the test done by Jacob.... (Taken from CACO)
Power Test Completed.
I know someone will ask these questions SO READ THIS FIRST :
1) AQ-3500D Tested First - Battery Bank had a charge for several hours from our bench power supplies
2) SAZ-3500D Tested Second - Only a few minutes behind the AQ-3500D Test
3) THIS IS WHY the 3500D had much more voltage drop, I had the entire surface charge gone from the batteries
4) Both amps set wide open to be apples to apples.
AQ-3500D POWER TEST:
http://www.sundownaudio.com/misc/_AM...D/CIMG2679.MOV
AQ-3500D VOLTAGE TEST:
http://www.sundownaudio.com/misc/_AM...D/CIMG2681.MOV
POWER : 2400 Watts
AMP VOLTAGE (measured) : 71 V
AMP CURRENT (calculated) : 33.8 A
ACTUAL IMPEDANCE (calculated) : 2.1 ohms
SUPPLY VOLTAGE : 14.22 V
SAZ-3500D POWER TEST:
http://www.sundownaudio.com/misc/_AM...D/CIMG2682.MOV
SAZ-3500D VOLTAGE TEST:
http://www.sundownaudio.com/misc/_AM...D/CIMG2684.MOV
POWER : 3020 Watts
AMP VOLTAGE (measured) : 77.2 V
AMP CURRENT (calculated) : 39.11 A
ACTUAL IMPEDANCE (calculated) : 1.97 ohms
SUPPLY VOLTAGE : 11.99 V
There are all kinds of Ideas out there by a search on the internet these days. Find the one that works for your situation and budget and...
Hey there I've had this Axxera AV7336MB for years now, but it's got some issues and needs to be replaced. I went to go buy a new one, only to...
Have you browsed the Audio Control DSPs, like the DM608?
I love my m25 tweeters and will likely try the tm65mkiv or tm8 next.
Plottin4success
Plottin4success
In a kitchen, Louisiana
Plottin4success
Brendon Jenness
    May 8, 2024
    May 8, 2024
