Good alternative to Sundown??? 2000w rms
If there was an "alternative" to Sundown that was of the same specs at a lower price, people would be all over it.
I agree. But some people buy just for the name. I.E....Fanboys
Sundown is not the ONLY way to go, though some think it is. Im just looking for something a little more in my price range that is till just as dependable and does clean, rated power.
I lucked up on 4 1500Ds a while ago. Before that I had the AQ2200D. NEVER had an issue with it at all. I used it for maybe 8-9 months. I took it out because I changed setups. Price was an issue for me as well at the time. Best deal going IMHO is the AQ3500 for 549. BNIB with a 1 year warranty. But if 12 volt ratings are what sells you on an amp, just save up for the Sundown. You already have the 4 channel so you won't have to go through the bother of finding a matching 4 channel. You could also check DB-r and I saw Jacob post saying that he had a few used 2000s. And though I haven't heard much of anyone using them, DC has a 1, 2, and 3k amp also. May want to look into those too.
Already talkd to Jacob.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The only reason I asked for something that was rated at 12 volts is bc I currently dont have the electrical to support 2000+ watts. Gonna get an XS Power or Kinetik batt after I get the amp. HO Alt is a LONG way down the road.
solid audio f2500d 395 shipped conus
RMS @ 4 Ohm: 700W x 1 Ch.
RMS @ 2 Ohm: 1300W x 1 Ch.
RMS @ 1 Ohm: 2500W x 1 Ch.
been clamped at 3700 at 1ohm at 14v
RMS @ 1 Ohm: 4000W x 1 Ch. @18V
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: EXTERNAL 200A Fuse
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 570mm Features
MOSFET Power Supply Amplifier.
Double Sided Through Hole Epoxy PCB.
Gold-plated Brass Set Screw Terminals.
24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
Variable Phase Shift
5 Way Protections
Daisy Chain Through Output RCA
Bass Remote Control
Power/Protection LED
1 Ohm Stable Circuits
Soft Start/Output Relay
18V Operation
Parallel Operation
Plottin4success
Plottin4success
In a kitchen, Louisiana
Plottin4success
