Going to Sound Deaden Accord today need advice
The trunk looks good. I'd use at least little bit on the higher areas. Make sure you have no air bubbles. Don't go crazy if you need to save some for the doors.
The trunk lid has two surfaces - the inside surface of the exterior sheet metal and the "X' braces and the area over the rear. Get as much as you can on exterior sheet metal. You can probably leave the braces alone. Then do the big, flimsy areas. Then you need to find a way to lock down the "X"'s and other areas that might want to rattle against the exterior skin. Expanding foam shot in carefully or silicone caulk will work. Put some on the back of your license plate if that rattles.
I think I am going to just use this whole roll up on the trunk. Should I still not do the high areas or would it be worth it? I have 60 sq feet to work with now.
Ill just order some more stuff for the doors. And I already did the license plate. I am going to finish up the rest of the trunk tonight when it cools off. Way to hot out there right now
Think this would be worth buying or is it complete garbage
http://www.caraudio.com/forum/showthread.php?t=331654
I'm assuming there will be a sub in the trunk. I'd definitely do the higher areas. Beyond that and what you've already done, make sure you have thoroughly hit the wheel wells. Then deaden the hell out of the rear deck. If you have any left (or have any left over after you do the doors) pulling out the rear seat and seat backs and the side trim will let you treat the areas alongside the seats, which can help a lot.
i can't wait to deaden today. actually i dont want to at all. when doing my lid and floor of the trunk my hands got torn up bad. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Yeah 15 inch sub running off 800 watts will be in the trunk so....
And what do you think about that deadener i linked to?
How come?
I got some of the eD stuff that was cheaper than that. I used it and some super 77 spray on adhesive. I'll look in on it today and maybe take some pix. I still have 2 rolls left for the rear deck and along the sides.
Yeah take some pics!
I bought that edead for 22 dollars why not. I might just end up sticking it over my rammat on the trunk floor for a little extra deadener. Either that or ill use it for the rear deck
Here are the pics
Not done yet but looks like I am doing pretty good on deadener I have pretty much left.
Any places I should get better and should I do the sides?
And here is how much deadener I have left. Maybe I will have enough for the doors....or at least one of them.
What do you think I should do with the rear speakers? They are gettind disconnected would it be better to remove them or just let em chill there
You can see them good in this pic:
darkhunter139
darkhunter139
PA
darkhunter139
