going active
Is there something wrong with the kicker rs because it seems like some of you think i should change them. I dont paln on changing speakers with the car i currently have which ill probally keep for 2 more years. But then again i never that i would have bought half the stuff i have in my car now.
I went active on my rainbows. With all the r&d they went through and a crossover setting at (I believe 3.8khz). I set the range from 63-2.8khz on my active setup and can tell a much bigger difference than before. The speakers really have more "warmth" to them. Hard to describe, but it is definitely an audible difference.
I decided to go active for numerous reasons, future active setup ability being the largest. Now I won't have to worry about buying component sets or passive x-overs. My choices are larger now that I can pick & choose tweets, & mids to fit my needs/desires.
Another plus is that you're not limited all the time to the tuning. If you have a song that you want to change crossover frequencies on you can go ahead and do it. Control from up front > minimal control from the amp.
If you can, go active. If you need or want to upgrade your speakers you can, and you won't be limited to choice.
What makes it a good active setup besides setting the crossovers for the mids/ highs. I already think it sounds good but since i have a 4 chnnel amp and plan on getting the 880prs i just figured id give it a try.
eqing it and setting up your time alignment. also selecting good crossover points and slopes, having your speakers aimed good etc.
orioles26
orioles26
Severna park, Maryland
iceteebone
