Going active questions
JoshC
The Taco MASTA
Im in the middle of changing my front stage to active via a sq 4-90. Although i have a question for the final setup.
From what ive been told thus far, i want my high amp to be in bandpass mode for active. The 4-90 settings say LP/BP, so low pass is bandpass? Im very confused on this, i thought the HU was going to control all crossover points. When i did some google searching i found the guys on DYI audio saying when running active the amp should be in full pass mode, so which is it?
HU is a 80prs, ive got the right doors passive xover pulled and am about to pull the lefts. Going to finish this up tonight and see if the sound is any better.
before i got the 80prs i was using the crossovers on my amps.
setting up the 80prs i put my amps on full and have all my crossovers on the h/u .
like i said you want...
highs = high pass
midbass = band pass ( that way you set the high and low for that speaker )
mid range = same ^^
on my system..
highs 3k and up
mid-bass 60hz to 250hz
mid range 250hz to 3k
bass 20 to 60hz.
but as you can see im running a true 3-way front stage.
that just gives you an idea.
you can do either.if you use the h/u crossovers put amp on full.
highs get = hp
mids get = bp
i do like the sq amps crossovers.
nice wide range.
Okay, so i do want to use full pass if i want to control all crossovers at the HU. So in full pass will i still see the -24db slope the amp uses or will is see whatever my HU sets it too?
yes set to full.you set it at h/u .
as it looks like when in full there's no set slope.
as the manual says slope in high , bp , lp .
Okay i got everything changed over and reset it, just turned my gains basically to nothing for this test.
Set the unit to
Sub:
80Hz -24db
For mids.
Hpf 125hz, lpf 4kHz -18db
Tweets
Hpf 4kHz -12db
Still in the parking lot so i couldnt actually turn it up, but hopefully it will sound good tomorrow. Although i had an issue getting my right tweeter to work, then it played fine but i noticed my balance is all messed up. If i fade to the left the right tweeter is silent as it should be, but if i fade right my left tweeter is still playing just at a lower volume.
I have left tweet at ch1 and right at ch2, left mid at ch3 and right at ch4. Could i have mixed up the RCAs behind the HU so its getting confused? Like its matching right woofer to left tweeter or something.
Really digging all the different options i get to play with, next step is to make the doors truely dampened and sealed off.
Set the unit to
Sub:
80Hz -24db
For mids.
Tweets
Hpf 4kHz -12db
i would definitely verify your rca's, i've crossed them before myself. fortunately the front and rear in my set up output the same full range signal highpassed at 80hz, but in your situation you could end up sending the midrange RCA output to your tweeter, it's a little more important lol
not sure if this was clarified or not, in the OP you seemed a bit confused about bandpass, lowpass, highpass, and how full range is necessary at your amplifier if using HU crossovers.
bandpass is a combination of high pass and low pass
the rca outs for your tweeters will need only a hpf
rca outs for your midrange will need a bpf
rca outs for your sub will need a bpf. you said 80hz 24db, is this a LPF? you'll need a HPF as well (i.e. subsonic - a HPF for extremely low frequencies below your box tuning)
you'll leave the amp on full pass due to your control being done at the headunit.
Set the unit to
Sub:
80Hz -24db
For mids.
Tweets
Hpf 4kHz -12db
sounds like your rca are on the wrong ch.
switch them.
if not make sure the h/u is setup right.
but looking good.
good point.
but on sub output you only get lp.
so on your sub amp you need to set subsonic filter.
JoshC
The Taco MASTA
JoshC
Houston, tx
wew lad
