Going Active on a 4-Channel . :crap:
mikeyboc
Here is a rough diagram of the RCA inputs and speaker inputs on the side of the amp. I labeled them with how I thought it shoudl be wired, but just wanted to double check before trying to finish it up tonight.
What I can up with is:
Connect the HP from the DQX to the 1 st set of RCA's (looking from Left to Right)
Connect the BP from the DQX to the 2nd set of RCA's
Tweets wired to Left A and Right A
Mids wired to Left B and Right B
I guess I am alittle unsure if the RCA's will correspond to the speaker terminals (don't want to hook the tweet to LEFT/RIGHT A and have it get the bandpass signal). Is this right? Or is there a different/better way (read "or am I just wrong")?
Audison VRx 4.300. The RCA inputs are labeled just as they are in the diagram.
IN - OUT - IN , with the L and R verticle below each. If you were to run 4 coax speakers you would hook the Left Front to the Left Speaker A, Left rear to Left speaker B, and so on. I assume the RCA inputs would take the L from each input and designate it over to the Left speaker terminals, and R to Right.
Let me see if I can pull up the manual . . .
i don't understand what you trying to do? why don't you just hook them up according to the diagram?
I wasn't sure that the HP signal coming from the x-over would be relayed to the Left/Right A speaker terminals. If I wire to the diagram, and the tweets and mids are reversed on the speaker terminals, then my tweet will be getting the BP signal. Does anybody know what speaker terminal (A or B) the first set of RCA's on the left matches with.
I guess I am not expaining it right. Hope somebody gets it.
NVM, I am an idiot and was over thinking the situation. The diagram from the manual shows the front input going into the left RCA's and the front left and right on the A speaker terminals. My original diagram was right. Flame away for posting an answer to my own question. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
haha that's what i was saying. i was like uhhh follow the diagram. lol well looks like you got it.
mikeyboc
mikeyboc
Sugar Land, TX
alphakenny1
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
