How can you design the woofer around the box without knowing what box the person will be using? Different vehicles have different transfer functions and not everyone wants the same FR out of their subwoofer. The only company that I know does anything like that is DD as people generally want loud when they choose DD subwoofers. I'm quite aware BigRed uses DD subwoofers, but honestly, I'd say his perfect scores are mostly a reflection on the fact that his midbass to subbass transition is good as that's pretty much all they judge at SQ comps. If the bass isn't behind you and it seems to hit the lowest notes then your good to go. Kicker made plenty of SQ cars too for this very reason. Anyway you should elaborate on the better transient response as I don't see how having two radiators, both a a speaker and port that aren't even in complete phase would EVER have better transient response. You added more variables to a non-linear system.
Anyway Pete is a great designer, I know he uses Akabak, which is a very poweful design software, albeit hard to use for most. I'd also agree Ported enclosures are better for SQ in a car. Transient response in a car is a moot point since the subs are behind you reflecting 8000x times in a tiny car where almost every frequency is simply pressure mode as the waveform has no room to develop before reflecting. The extra couple m/s isn't going to matter a bit. However, when you use a ported enclosure you can cut down on excursion dramatically as well as use less amplifer power. Once you have more ouput than you can ever need to can shape the frequency response anyway you want without worrying about distortion. I'd rather do that than shoehorn a sub into a tiny box and get frequency response that is relatively close right off the bat, but have terrible dynamics as a result. Anyway since had a hand in it, what tuning frequency and box size is he using when he's competing, I was always curious?
Anyway most research on transient response shows that anything below 18m/s in subwoofer territory is ok. That's in a perfect room with good hearing, go into a car an any value you would get in even a decent enclosure is going to be ok. I doubt in the real world anyone can even tell, the better "transient response" that people think they hear when using a sealed enclosure is mostly due to a better frequency response, which a ported enclosure can very well do the same thing with even better dynamics!
