T3mpest, this is not directed at you,
You're right high moving mass doesn't effect the transient response directly. Transient response is dependently controlled by the enclosure. With enclosure designs, the lower the moving mass, the lower the transient response in most cases. The other factor in lowering the transient response is a high motor strength. The combination of high motor strength and a low mms allows for the extreme accuracy in a ported type enclosure. I guess you can say they're indirectly related though.
When I first started doing enclosure designs, I followed strictly with Dan Wiggin's papers and I'm quite aware of Stereo Integrity's documentations. However, I've found their theories no longer applicable with some of my newer designs.
Remember years ago, many said that a ported enclosure can never be louder than a ported enclosure. Time went by and it was de-bunked quite quickly. Next, the new idea: ported enclosures can't sound as good or be as accurate as a sealed enclosure. I've been saying this for years: "a ported enclosure will always have a better transient response than a sealed enclosure." I was challenged by many by of this, but I've always stood my grounds. My designs aren't based on traditional theories. The more I learned about acoustics in a vehicle, the more I've realized we're far from understanding the fundamentals. Recently, the person that won the IASCA regionals had a ported enclosure with 2 15" DD9515's. He won in 2 categories with a perfect score in sub bass. I designed and built this enclosure. Many people were shocked by this. Let's just say that I've figured out a decent formula but it still requires the concentration of 2 factors: low mms and high motor strength. In real world application: what is the point of design a perfect subwoofer in theory, but when applied with an enclosure doesn't quite work. Many manufacturers need to reverse engineer and design the subwoofer with the enclosure as the main "real world" factor prior to anything else.
While I understand and appreciate theories for it is the fundamentals that has taught me foundations. But, with what I do...these theories are being broken everyday. My good friend Pete from PWK Designs will be the first to tell you this. In my books, he's one of the best enclosure designers out there. Pete has a particle collision engine theory and calculator that is the most accurate and makes theoretical softwares such as Bass Box Pro or Leap look like grade school.
There's a lot more we need to learn and it takes controversial issues and debates to get new ideas or to re-enforce the old ones.
Tuan
