No, no, and furthermore no.Do
not drop a 2 Ohm load on any channel of a HU's internal amp. Unhappy results will be soon forthcoming if you do.
pyoung9?
You're going to want to invest in an outboard amp.
There simply aren't any headunits available that offer a strong enough output to truly satisfactorily power aftermarker speakers. Can you technically do it? Certainly. Will the sound output be exponentially better off of an outboard amp as compared to the internal amp in your HU? Again - certainly.
If your budget is tight there are several brands which have units available for lower-budget setups.
Buying used from the Classifieds here is also an option if you're trying to save some coin.
eBay is also another decent venue from which good deals can be sourced if you're willing to be pretty diligent in your research - both on the product(s) you are considering as well as the seller(s) who is/are offering them.
