Giant 4th Order: Worklog
i dont think they were bottoming out...
however, I have seen some subs acting weird from being underpowered. For example, we hooked up a pair of MTX Thunder 4510's up to a JL 500/1 at 8 ohms. On drawn out bass notes, one sub would reach full excursion, and the other would hardly move, and then it would slowly shift to where the other sub was at full excursion. But when we dropped it to 2 ohms, and let the subs see enough power, they wanged just fine...
long string of series wiring FTL. Perhaps you had one of the coils out of phase.
This could actually be the problem, might need to redo a little wiring. Luckily we have access to the subs in the box because you can fit ur whole body inside the port lol.
nope, i actually took one of the subs back out and reversed the polarity, and that way was def out of phase. so i put it back and it was still funky, so i just switched em to parallel and bam
And if you had only one coil out of phase...the woofer with that one out of phase coil wouldnt move...Because in theory the coil in that sub would be "working against" each other...Just pop the lead wire into the box with a 9v and make sure all the subs move the same way.
the subs were SVC, wired together in a sealed box... so i had to take em out anyways... I've been at this car audio thing long enough how to test if a speaker is in phase..
anyways... how bout that 4th order.
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
jmanpc
CA.com Nostalgist.
jmanpc
Jacksonville, Fl
jmanpc
    May 31, 2024
    May 24, 2024
