getting some really LOUD engine noise in my subs!
loudcar412s
14
TN
i have 2 polk 12's, a lanzar vibe 435 (i think thats right...?) 1000w amp. i had it in my blazer and got no engine noise (it was also with a much better cd player) and now we put them in my friends car and his engine noise is SO loud coming from the subs in the trunk.
what is causing this and how can i fix it?
Engine noise is usually a high pitched whine coming from mids/tweets. Ground the head unit and amps to the same point. Make sure it's a good ground point. make sure the back of the headunit is not touhing metal.
Originally posted by indosia Engine noise is usually a high pitched whine coming from mids/tweets. Ground the head unit and amps to the same point. Make sure it's a good ground point. make sure the back of the headunit is not touhing metal.
So what your saying is, i would have to run a cable all the way to my trunk were my amp is? Arent you supposed to make the ground cable as short as possible?
Please help
how do you know it is a signal ground loop?
Please help
I can't help untill you mute the amp
What do you mean when you say mute the amp? and what are muting plugs?
Thanks
shorted out RCA jacks----hack off some old RCA ends and connect the center prong wire to the outer shield wire. shorting out the plug. make enough for all channels of the noise making amp. plug em in and tell us what happens. Do you happen to know the source imedance of your HU?
Before i make some muting plugs, i thought you might want to know that when i disconnect the rca's runnin to the amp the whinning stops on my sub. So is that anyhelp? my HU is a Aiwa cdc-mp3 im not sure on the impedeance.
k--- move the HU to the back of the car and use gender connectors to plug the HU DIRECTLY into the amp. connect the HU positive and turn on and ground to the amp also ground the case of the HU the terminal too . Do you get noise???
loudcar412s
loudcar412s
TN
taylor
vegang
vegang
