Getting back into audio big build wiring/ electrical help!?
  • 1
Spldecendant
Ny
I have been out of audio for awhile. A 2002 Escalade came up for a good deal and I started building it. My previous build I used 4 runs 2 pos 2 negative of knuconceptz 0 gauge ofc wire. This new build consist of 4 18 rs teams in a 4th order bandpass. The plan is to run 4 taramps bass 15k one per woofer, a Rockford 1000/2 for some mid range and 2 sundown sfb 3000’s for each front door. The stock alt and battery to run the car stand alone and 3 mechman 370’s for the system. Now how many runs of 0 gauge pos and negative should be run from front to rear. Also I was going to put about 4 ground on the frame up front and 4 grounds on the frame on the rear is that sufficient? Now for reserve I was looking at cyber limitless lithium Batteries, is there better options out there and how many/ size should I run, I’m not to knowledgable with lithium as I used agm a couple years back. Also should I still use knuconceptz ofc or is there better options out there now? Thanks
Here are the reasons of my assumptions and why I think there is little danger in this setup. 1. Bared conductors could cause a spark that leads...
38
4K
Appreciate the input! I'll check out the calc site and see how it compares. I'm in the beginning stages of building the box. Unfortunately with...
658
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
I'm putting 2 under my rear seats with 2 passive radiators. Only a 3kw amp. Only reason I'm selling my adire subs before even trying them. Granted...
20
Spldecendant
Spldecendant
Ny
Spldecendant
SlugButter
    May 4, 2024
slater
    May 2, 2024
