Getting 2X AudioQue HDC3-A 10's or 12's. Need help
Sanchito
O.G. status
Which coil options should i go with to make the wiring easier?
Which way should i wire them to make the amp hookup easier?
what would my finall ohm load be and what wattage should i be running to the set?
Which size you you guys recommend in the trunk of a 09 civic for a daily driver?
get your copper 10's. If you wanta be loud hook em to an AQ2200. If you wanta pound hook em to an AQ3500. If you wanta be sick hook a 2200to each. Make sure to get the correct wired subs for the application. Call DJ at Audioque to get it right.
Sanchito
O.G. status
Sanchito
Houston
mlstrass
