Germs or Profi kicks
ha ha...I was (at least) somewhat correct. I am getting the car audio stuff. Not just a repeater but evidence. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Also, to OP. If you are dropping it in a basket you might need to consider how the basket to the profi's are formed. They basket is rather wide and you may need to make a small ring rather than dropping it straight in a plastic OEM baffle. But IMO it makes it much stronger.
Use Goop to bond the plastic to the wood. It does a pretty good job of bonding but will give up the grip if you mess up and need to get the ring off by smashing it with a hammer.
Youve come a long way grasshopper. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
A standard MDF ring will suffice. They hate with a passion to be enclosed. Originally intended for IB and off axis, they utterly hate solitude inside things. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I DONT LIKE DLS ANYMORE- POOR CUSTOMER SERVICE. vanadiums, huh? which do you think would crank : cdt es07 paired up with cdt es01 tweets or your vanadiums
Something changed in the past several Hours?
Couldnt tell which would 'crank' better. I have yet to make a subjective comparison with 'cranking' as a target.
And Please change your avatar, its quite disturbing.
dvrmstrng
dvrmstrng
DE
6spdcoupe
