6spdcoupe
tends to get a bit cranky
You would be better off looking at Vanadiums. But why not Iridiums????????????????????????????
Youve come a long way grasshopper. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifha ha...I was (at least) somewhat correct. I am getting the car audio stuff. Not just a repeater but evidence. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Also, to OP. If you are dropping it in a basket you might need to consider how the basket to the profi's are formed. They basket is rather wide and you may need to make a small ring rather than dropping it straight in a plastic OEM baffle. But IMO it makes it much stronger.
Use Goop to bond the plastic to the wood. It does a pretty good job of bonding but will give up the grip if you mess up and need to get the ring off by smashing it with a hammer.
Something changed in the past several Hours?I DONT LIKE DLS ANYMORE- POOR CUSTOMER SERVICE. vanadiums, huh? which do you think would crank : cdt es07 paired up with cdt es01 tweets or your vanadiums
Its the motor in that XXX.what is xbl^2 and why couldnt the substage play up that high?
Kick yes, standard no.so what was he saying...that the xxx 12 and profi kicks would no cover all ranges of sound?
Yes or no question correct? Answer is above.so what was he saying...that the xxx 12 and profi kicks would no cover all ranges of sound?
