headless
Not really; i still don't know the answers to the questions i posted. Every time i ask direct questions i get vague responses like yours. I know WHY the bulbs are there; to protect your tweeters from overcurrent of course.. - i want to know how they function and what causes them to glow. Is it overpower, or simply power? Do the bulbs act as glorified fuses, or are they only supposed to light when you're pushing too much power to the set? If they only light up when you're overpowering the set, it appears that they consider 110w per side as too much power...and 4x50w biamped too! I don't think that's the case, because the specs read 150w per woofer and 150w for the tweeter as their rating. Why have protection that cuts on at less than 100watts input if your components are rated @ 150w each? I'm starting to think that nobody who speaks english really knows how these crossovers and protection circuits work.You kind of answered that your self. They are there to protect the tweeter from excess wattage so they do not blow. How much power are you feeding them? You wont need much power when going active we usually run a max of around 120 watts, which on an active setup is pretty loud. 75 watts will do must justice.
I was feeding them 4x50w biamped, and the lights came on then at reasonable volumes, though they were nothing like what i'd consider 'loud'.
Then i swapped the 4x50 to bridged @ 2x110w or so, and the lights came on then. Louder, but not 'loud enough' in most cases for my liking.
I was suspicious of my 4x50/2x110w eclipse amp and thought maybe it was clipping the signal at higher volumes, thus causing excessive power RMS values which would cause the PTC to engage...but
Now i've got a 4150XXK, bridged to 2x320 or so...and the lights still come on at high volumes. I've got the gain at an extremely low setting and my HU is not clipping the signal. I'm fairly sure i'm not clipping the amp as it's not even pulling 200watts on the input side before the lightbulbs start glowing happily.
Do you think that removing the passive x-overs would result in an overall increase in volume? I find that the lightbulbs come on well before i get to a volume that i consider 'loud' and that's considering i've only got a 12w6 (version one!) on only 300watts..SEALED... so I'm not drowing them with bass.
While they get loud, and they stay clear, the lightbulbs make me wonder if going active would result in damage to the speakers.
What do you think? Do the lightbulbs indicate that the tweeters would be damaged right then if they were not present? or do they indicate that power is flowing and nothing more? If i were to go active, it would be with my 4150xxk which can put out about 100watts*4 @ 4ohm.
