Papermaker85
Banned
- Thread Starter
- #16
The lower the tuning the more Port area this is because a lower frequency requires more Excursion therefore the lower the tune the more Port area you would want. As long as you're not getting any compression or noise you should be good.This is interesting however. Some vague generalizations that arent always an end all be all. Like power input for example. Im running a sub with 30mm in a 4.2cu box...but im running double the rated power and can max it out mechanically easily...how much port area should i be running? Also, im tuned low, 29hz...and from my experience you can do less port area tuned low....so for those more knowledgeable than me, how much port should i run? Curious to see how close, or far off I am
The only reason people associate box size with port area is because a larger box allows more Excursion with the same amount of power.
This is the reason that the formula is solely based on tbe subs displacement and tuning. if in your specific box the woofer itself is capable of 30 millimeters each way with a sd of 120 inches (cone area) you should have between 80 and 100in^2..
