99gtxgolfer
the problem is...
BTL hooked up to autotek 3000.1
Empire audios x4 hooked up to autotek 100.4 with tbi hdss tweets
when i have everything on mids highs and woofer when i play for example (Put on) it cuts out at a curtain part in the song...even at 25/31 i looked at the trunk and saw that it would cut out and the amps would turn off then back on...
i know the 100.4 needs to get repaired (one channel is messed up)
when i have just the mids and highs on with woofer off everything is fine...
today however my jank stinger volt meter has been reading some abnormally low numbers. usually i see 14.2- 14.7, this morning volt meter is going every... from like the high 12's to the 14's...im going to get a multi meter and check the voltage from the amp.
anyone know why it cuts out when i turn the volume up? and how do i fix it???
Big 3
200amp alt
hc2400
1/0
Big 3
200amp alt
hc2400
1/0
