General Ohms Question
ShamRockv
I'm generally pretty confused when it comes to ohms, but I am thinking of buying 2 10" Image Dynamics CTX108(from what I understand this is a solid brand for these entry level subs) which are 8 ohms and i have a pioneer GM-5000T amp, the link for the specs are here. I am pretty confused because the amp specs give a range of what ohms it puts out...is this determined by what omhs the sub has?
Will my current amplifier do these subs well?
As a side note I'm going for SQ.
Thanks in advanced
yes that amp should work well. you did good pairing two 8ohm subs with a 2 channel amp. you'll be able to bridge the amp since the subs in parallel will yield a 4ohm impedance.
time alignment is not the same as volume. Time alignment is usually only needed when you have an amp or multiple amps, and one has a delay. I...
Looks like it's wire it either 4 or 8 ohm 🤔
858
Okay. Thank you so much! I will run individual power / ground wires to each amp. If the front of the car has no dedicated spot for tweeters, what...
883
You will need distribution blocks for the amps I would run 0 gauge to the blocks and 4 gauge to the amps. For the head unit I would us one that...
Yeah, if you haven't bought em yet, then get a matching third sub. I would wire them to 1.3ohm, unless for some reason, you have some really...
ShamRockv
ShamRockv
Richmond, VA
ShamRockv
