General Ohms Question
ShamRockv
I'm generally pretty confused when it comes to ohms, but I am thinking of buying 2 10" Image Dynamics CTX108(from what I understand this is a solid brand for these entry level subs) which are 8 ohms and i have a pioneer GM-5000T amp, the link for the specs are here. I am pretty confused because the amp specs give a range of what ohms it puts out...is this determined by what omhs the sub has?
Will my current amplifier do these subs well?
As a side note I'm going for SQ.
Thanks in advanced
yes that amp should work well. you did good pairing two 8ohm subs with a 2 channel amp. you'll be able to bridge the amp since the subs in parallel will yield a 4ohm impedance.
ShamRockv
ShamRockv
Richmond, VA
ShamRockv
Mike Mccabe
