Gas Tank Problems
Hey anyone out there ever had issues with their gas tank leaking. For example, I used dynomat on my trunk lid and the top of my new gas tank on my 65 cutlass and I noticed that the tank is leaking tonight. I have 4 massive hippo 12 ported on an Orion 5000 HCCA. What should I do, how to fix this problem. Would using dynomat in my trunk under the speakers help or is that a waste of time and money please help because this is taking my funds, especially when I am on my third gas tank, and I barely drive the car.
Are you saying the bass is wasting your gas???? It sounds like you poked a hole in your gas tank. I've been there and did that JB Weld will take care of it if the tank is metal if it is plastic put a bigger screw in the hole
Yes the bass is killing my tank, so you think the jb weld will do the trick. Also, for a 65 cutlass the replacement gas tank does not come with a neck so I had to cut the neck from my old tank to weld on the new on. I popped a pin hold where the weld is made on the neck, do you think the JB weld will fix that also.
Ive been in a Dodge 2500 with that 5.9l Cummings and witnessed it turning on the 1Mill. Mile marker, and still ran great a couple years later.That...
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
775
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
820
Jaybo
Jaybo
New Orleans, Louisiana
The Camry
    May 18, 2024
    May 18, 2024
