gain
BumpinTypeR
MD
Hey guys,
I reset my gain today using a 50hz test tone and a DMM on my alpine mrp-m500 amp cause i was unsure if i did it correctly the first time. and for some reason after everything was done the gain knob is not turned nearly as far as it came out to be last time (it ended up right at the "nominal" marker on the amp this time, last time it was tunred quite a bit further) and i thought did the same procedure as last time. Not sure why it came out to be dif. I do have a better mix of bass/music now....before my bass almost drowned out my music.
question tho, are the loudness and super bass eq setting alright to use? i know bass boosters are not good to use, but not sure about these.
and i set the gain with my LPF at 100hz and hpf at 125hz...is that ok or should i of had my hpf/lpf off? I did have my eq to flat and loudness off and my volume on my HU at 75% when doing it.
thanks
BumpinTypeR
BumpinTypeR
MD
BumpinTypeR
