Hey everyone,
Ok so I understand that setting the gains properly is to have the right amount of volts to give the rated watts. For example My amp puts out 850W@2 Ohm, and to do that it needs 41.2V, so I need my gain to give me 41.2V...
I need to set my HU to 75% (i dont have an osciliscope) which should be the max volume before clipping, play a 50hz test tone and then turn the gain until 41.2V...
This means when my volume is at 75% I am giving my sub 850W (in theory).
Now the questions:
1. Daily driving I don't go past level 18/35, my gains are set for 26/35. So if I'm playing at 18/35 I can turn the subwoofer output up to like +10 lets say so that the sub lines get more volts and not the rest of the system, right? Because my sub might be able to handle 26/35 but my coaxs wont be able to. Could I set my gains with the volume at like 20, subwoofer out to like +6 and set them to 41.2V, that way I could have it dead on 850W for daily driving? Or should I set it as normal and simply turn up the subwoofer out if I want more bass at 20/35. Should I test how far I can put the sub out to at 20/35 before it goes to 41.2V?
I think all that is valid, is all that true?
Second Question:
2. My sub is a 12" type-R and my amp is an MRP-M850...The R is rated for 500W RMS, but can apparently handle a lot more...up to like 1000 daily. The amp puts out 850W. How can I tell if the sub is getting too much watts? Could I tell from the excursion? Would I hear it? How do I know if I'm pushing it too far? Is there any way to measure it?
Thats it, thanks a lot to anyone who takes the time to read this and give me some input //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Now the questions:
Second Question:
