gain setting ? strapped kx1200.1 ( need a little help )
UNDERGROUND_BUM
ok so ive got 2 kx1200.1 strapped running at 2 ohms, but i need a little help setting my gain with my dmm.......
so using the equation Sqrt(power-about 2500rms*resistance-2 ohms)= voltage ( about 70) is this correct? how did others with strapped kx1200.1's set there gains? where do you get the reading from ?(master, slave amp or both) just need a little help, ive never strapped amps together:D
wiring for stapping these amps together is the following ( neg speaker terminals on both amps connected together) (postive speaker terminal from one amp is used for a negitive for the speaker/ speakers ) ( postive speaker terminal from the other amp is used for a postive for the speaker/speakers)
You would get the gain voltage from where the speakers hook up, so in this case it would be the + on the master and the + on the slave.
When strapping it makes 1 big amp so set it as if it was just 1 amp. I have 10 of these so I know atleast that much //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
thanks alot guys i guess im gunna go set my gain and bump around town ; )
Enjoy it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Let us know how it turns out.
And yeah you'd only set the master, hence why it's called 'master' //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
UNDERGROUND_BUM
UNDERGROUND_BUM
HAWAII
x2o
