Gain setting on amp
loz88
15
UK
Hey guys I did the method where I calculate the gain to set my amp to using my multimeter.
The sub is 125rms at 4ohm and the amp can do 200rms at 4ohm.
Now I did the calculation using 125rms and it sounds good but the bass isn't as loud as I like, I feel like my components overpower the sub.
So I increased the bass boost some and increased the gain, it now sounds how I want it to and I can't hear any distortion.
So I have a few questions:
Does this mean my sub can handle more power than it was rated for?
Can I set my gain using 200rms instead in this case?
What is a good normal bass boost on the amp? I have it on about 4db at the mo.
Thanks
Did your math account for Box Rise? If not you may have set the gain too low. Also not a huge difference in power handling from 125W to 200W. If your sub isn't distorting or bottoming out your likely fine...
BTW What sub is only 125W?
Its a jbl cs10, I actually have it mounted in between my ski pass as I have convertible I can't hear a box in the boot as the boot is separate from the car, this isn't actually a free air sub but maybe that is why?
What is box rise?
So... it isn't in a enclosure? You're running it Free-Air? That sub isn't meant for Free Air usage, and yes would be why you can't hear it.
As for BOX Rise, when your sub is actually in a box, based on Frequency being used your Sub's ohm load will rise, resulting in less power reaching your subwoofer.
loz88
loz88
UK
bigblank69
