BlkonBlkFG
I understand the way to figure out the voltage reading for setting the gain on an amp. I understand the concept, but do i use the 12v ratings or the 14.4 rating on the amp?? Cause I know my amp for the internals is rated at 12v....should i use the 14.4v rating for everything? However I've read different posts that say to use a 0db (here) test tone and a 1khz test tone (jl website). My question is which tone do i use? My other question is....does this have anything to do with the crossover setting? Or do you just adjust the crossover setting after you get done setting the gain???
TIA
Josh
TIA
Josh
