You can buy $50 clamps at Lowes, they work good enough.
Formula that I know is this:
AC Volts x AC Amps = power output in watts
AC Volts / AC Amps = Impedance
So:
50VAC x 50A = 2500 watts
50VAC / 50A = 1 ohm
Typical impedance rise from .5 might be higher than 1 ohm, at tuning frequency, it will be closest to 1 ohm, but will go much higher as you get away from tuning frequency so it's a blind test if you ask me... Like I said $50 clamps at Lowes if I remember right... Maybe even less than that, like $45. You can use the DMM you already have to check the AC Volts coming out of the amp and use the clamp to get the AC Amps.
You can't measure the output power with a scope, or the impedance, but you CAN tell if the signal is clipped or dirty in anyway with a scope, but that would be way more of an advanced set of testing on an install than most people will ever do. A cheap DMM and Clamp will get you started, and check, DMM's are like $10 at Autozone or Oreilly's and cheap clamp is $40-$50 at lowes and you can test all day and know alot about your setup for under $100. It's worth it. And yes, some scopes are cheaper than some RMS Clamp meters. I use Fluke here, but they are not True RMS, don't really need to be either, save your money, buy the standard stuff it will read nearly identical to the high dollar "true" rms stuff. I have had bad luck with cheap DMM's reading incorrect volts though, so beware on the $10 DMM's, maybe buy a $40 DMM along with your $40-$50 clamp meter so you can at least get decent readings. IMO WAAAY better than relying on a "guess" as to what you impedance is by just using a DMM.
So:
50VAC / 50A = 1 ohm
